No display on Monitor after motherboard upgrade
phila1206
4
HI All,
Just wondering if I can get some help.
I recently brought some upgrades for my computer( msi Z97 U plus motherboard, nzxt x41 cpu cooler and nzxt h440 case) , after putting it all together, I cant get a signal to a Monitor.
The computer turns on, all fans start to run, but the GPU fans start and stop every few seconds, and I cant get any display on the Monitor.
I have tested the GPU in another computer and it starts up fine. Its a GTX 680. I also tested another graphics card, a gtx 770, in my new set up, and the fans on that spin up fine, but still no display.
Is this maybe a PSU issue? I have a corsair cx750w. It was from my old computer, which was unfortunately smashed due to certain circumstances haha, im just thinking maybe something in the PSU has been damaged.
Or maybe a motherboard issue?
Any help would be great
Cheers
Phil
phila1206
4
Thanks All,
I re used my SSD with windows 7 pro already installed.
Is this the problem?? Should i back up the stuff and re format the drive and try again.
The next option is to send the Motherboard back :(
jimpz
802
I would do a reinstall, your current SSD/OS has the drivers from you old hardware & is most likely the problem,
While a bad mobo could be the issue, you could send it back, get a new one & same thing.
Againstgraphics
36
i have used a windows 7 drive in another system and it worked perfectly fine
jimpz
802
Nightowl, sometimes, if the mobo's are close, it will work, many times it will not & a reinstall is needed. (occasionally when it 'does' work, you may have occasional problems that you don't associate with, but are caused by the old install.
phila1206
4
Hi All,
Just wanted to let you know the problem is now fixed.. A stupid mistake on my behalf haha.
I had the ram plugged into the 2nd and 4th slot on the motherboard.. As soon as I swapped it over it it started fine. I did re install my OS as well anyways.
I thought some one told me that ram can be either in the 1st and 3rd or 2nd and 4th. Just not in any other combinations, unless all 4 are filled. Obviously not haha.
Cheers
