No Display on monitor
Raintime
11
Hello i built a new Pc and ran into a problem. When i tried to boot up my pc for the first time, I was disappointment by the no display at all! As if i never connected my dvi d cable at all! It goes straight to sleep mode. I tried to use both a dedicated graphics card and the integrated graphics.
But nothing :c I then tried to install the same gpu into my own rig (this ones for my gf) and it worked just right. when i turn it on the fans spin the cpu fan spins as well, as if it was working normally. But no actual display!
Please help me! ill any good advise i cna get thank you!
the main specs are
asrock h79 pro4 motherboard
intel core i5 4590
8 gigs of adata ram
Yes the cpu fan does indeed spin, and the mobo is AsRock h97M pro4
hi i tried what you told me as well as a few other things. I used ram from my other working rig and still no signal. i took off the heatsink and re inserted it to make sure it was on right, still no signal. i tried tightening the motherboard power and cpu power. but no signal.
is there anything else i can try? the cmos didn't help me as well.
and say the processor didnt work i would still get an image saying error right? i did insert the cpu correctly tho.
how likely is it for the cpu to fail? wouldn't i still get some sort of error? because i am certain to have installed it correctly.
