No Display on Monitor
Jan 5, 2019
5
Hi guys,
So I have brand new PC and when I turn it ON lights turn on, everything looks good, but no display on monitor just black....
Pls HELP!
You have to plug your display cable into the back of the GPU, that is likely your issue. The motherboard port is for use with CPU integrated graphics, which the ryzen 2600 does not have, so you will get a black screen using the motherboard ports. Your display cable must be plugged into the GPU in order to use it.
Specs:
AMD Ryzen 5 2600
AMD A320
8GB DDR4 2666MHz
GeForce GTX 1050Ti 4GB
4xUSB3.1 + 2xUSB2.0 gale, USB2.0 + USB3.0 priekyje, PS/2, RJ-45, HDMI, DVI, Display Port
plugging in motherboard
