That seems about right for a 1050 Ti and Mafia 3. Even on low settings you only get to the mid-40s. Though it might be more consistent.
Not really sure you can justify it, that is the GPU it has.
There is always a budget gaming machine, just depends on what your budget is. Unless you grossly overpaid for that Dell G3, it probably has a better price/performance ratio than any other laptop you can buy.
$600 RTX3050 with an 11th gen i5. But in a few years you will be in the same boat you are now. An entry level GPU.
https://www.bestbuy.com/site/asus-t...oc=Narrativ&mpid=376373&ref=198&skuId=6512281
As for a desktop, if you are starting from scratch, probably going to be more like $800 or $900 for worthwhile gaming performance. It could be cost optimized down to $600, but it wouldn't be worth it I think. An i5 would be far more preferable with its six cores, and this is basically the cheapest GPU worth having at the moment. Paying for something like a 6700 or 6700XT or RTX 3060 would certainly put this in that higher price range.
There are also a few 3070 class laptops hovering around 1000-1200.
PCPartPicker Part List
CPU: Intel Core i3-12100F 3.3 GHz Quad-Core Processor ($105.98 @ B&H)
Motherboard: ASRock B660M-HDV Micro ATX LGA1700 Motherboard ($89.99 @ Newegg)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($54.99 @ Amazon)
Storage: Western Digital Blue SN550 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($41.98 @ B&H)
Video Card: PowerColor Fighter Radeon RX 6600 8 GB Video Card ($234.03 @ Amazon)
Case: Deepcool MATREXX 55 MESH ATX Mid Tower Case ($56.65 @ Amazon)
Power Supply: Super Flower Leadex III Super Pro 650 W 80+ Bronze Certified Fully Modular ATX Power Supply ($54.99 @ Newegg Sellers)
Total: $638.61
Generated by PCPartPicker 2022-10-19 13:33 EDT-0400
