My monitor shows no display . All of my fans are runnning and led lights. My psu is running . I removed my graphics card and tried to run it without it . I removed my ram and placed it in different spots. Nothing still. However my hard drive and ssd are not plugged in yet . However I’m getting no boot . Do I need my hhd and ssd to boot up the cpu . My mother board is working obviously and plugged in the cpu wire to my atx12v on mother board . Maybe I plugged in the wires wrong from my cpu to monitor . I plugged one vga from mother board to monitor, plugged one hdmi from graphics to monitor . That’s all am I doing something Wong? Still says no signal . I’ve even tried to use a dvi cable instead of hdmi for the graphics card . The only last option I could do is check if the cpu is on correctly Which could be the problem . However I’m pretty sure I matched the arrows correctly . Also I think I tightened the cpu to tight . Please help thanks
Specs: mobo asus 320mk
Cpu amd ryzen 1300x
Graphics gigabyte GeForce 1050
Cpu amd ryzen 1300x
