Been searching a while in the net for similar problems, but never really got a definitive answer.
I have a ryzen 3 2200g and an MSI a320m-a pro mobo, i then proceeded to build it, then installed the os. But after "Getting Devices Ready" the display went blank.
The pc is still running, the led from the keyboard works. So i pulled it out and tried again, only this time the pc wont get to post. Fan runs, and the led from the peripherals is lit.
But i can go to post when using my old gpu tho. I use an active dvi-d to vga adaptor without any external power whatsoever. aMaybe that's the culprit? I can't even see the vega 8 driver in my display adapters. What do i do now? I'm at a loss here
