No display with Radeon HD 5670 Graphics card
bvpkumar
4
Hello,
I recently purchased XFX Radeon HD 5670 graphics card and installed in PCI Express slot. But when trying to boot the system, I can hear the computer is booting with single beep sound but not getting any display. Monitor is not getting any signal.
My System config
AMD Phenom X2
MOBO-Gigabyte GA-M61PME-S2P
Power: 450 Watts with 19 AMPS at +12 volt line
Please help me to resolve the issue...
Thanks
Praveen
jdenova007
380
13
Does your PC work when using this built-in display? If it does, then check in your BIOS what the Default Display Adapter is set to. Should change it to PCI-E.
jdenova007
380
13
Card may be faulty... did you plug the power cable into the card? Maybe your PSU isn't strong enough to run this card... Make sure you have the monitor set to the right input... like digital(DVI) or analog(VGA)..
bvpkumar
4
As per card specifications, it won't require any external power supply (max power consumption 75W). I have HDMI cord and connected to monitor HDMI port but with no success :( :( :cry:
Similar threads
