Question No Display zotac 1080 amp with display port
Jun 25, 2019
5
Hello
Just brought a 2nd hand zotac 1080 amp at first i couldnt get it too work, could only get into bios and the screen would then just display "no display" Since then managed to figure out that i can fully load into windows when its connected via DVI or HDMI cable, and then once in windows it would then automatically display on the screen connected by the display port. (Using the same cable that i had used with a 1070 this got swapped back in a couple times and would still load up fine with the display port)
just wondering what can it be preventing it from booting straight into windows from the display port.
Thanks
spec
CPU: phenom x4 965
Motherboard: asus M4A87TD/USB3
Ram: 12gb ddr3 ram
SSD/HDD: sandisk SSD 240 and 1 TB hard drive
GPU: zotac 1080 amp
PSU: evga gq gold 650 ( 3years old)
OS: windows 10 1903
Might want to list your system specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Include the age of your PSU. Did you uninstall your previous GPU drivers prior to dropping in the new GPU? You're also advised to install the latest off Nvidia's support site manually.
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
hi added the specs and yes i used DDU to remove drivers then installed drivers from nvdias website
