Hi,
I've changed case and PSU for my system recently. Now my problem is that during boot, I get "No DVI Signal" error and USB (tried front case USB and motherboard USB, neither worked) is not working.
I've had dvi signal problem for the past few months, but usually PC reboot used to help (now nothing I can think of helps...).
I tried:
I just noticed that both my GPU and iGPU has DVI dual-link ports while I'm using DVI single-link cable. Can that be a problem? (though I used single-link cable with that GPU before and it worked...)
I tried:
■ Using iGPU. Didn't help, still no signal
■ Tried switching RAM sticks. DIdn't help
■ Booting without RAM. Heard no beeps, but PC turned off in a few seconds (don't know if this indicates bad motherboard)
■ Tried different monitor. No help here.
■ Tried different DVI cable, tried VGA cable.
■ Tried my monitor on other PC, it worked. (So my monitor is working)
