Last Saturday I bought a Sony XBR-65800B. I chose this primarily because I wanted a smart tv that I could run Kodi on and from what I've read, Kodi only installs natively on android and fire tv. I had Kodi running on a fire stick, but it was very laggy over the wifi, especially if multiple people started streaming to multiple tv's at the same time.
My house is completely wired with Ethernet running over cat 6. I have a Linksys EA9500 router talking to a AT&T modem.
The router and the modem are in a patch closet. The main closet connects to a 2 patch closets, one upstairs and one in the basement.
I've never had an issue with the network.
So I unpacked the tv and fired it up. It initially connected to wifi and everything worked fine, but I wanted to get it on the ethernet network. I connected the tv to the ethernet
and turned off the wifi. Nothing worked. I tried all the troubleshooting techniques and nothing worked. I hooked up my laptop to the same jack and used the same cable and it worked just fine. I hooked up my popcorn hour and it played movies just fine. I went back to the tv and nothing worked. I called Sony support and we went through it all again. The girl was very helpful, we walked through all the troubleshooting again and nothing worked, so she passed me to tier 2 support. This guy was an ass. He kept insisting it is my router and I need to call them. I didn't think it was my router. While I was on hold I tried 1 more thing. I grabbed a very long ethernet cable that I had used for testing and I ran it from the tv directly to the router. All of a sudden I could get to Amazon and youtube. I mentioned this and the guy said that it wasn't the tv it was my router. That still didn't make sense to me. I actually thought I knew what the problem was (network latency caused by the patch closets and the Sony tv ethernet adapter not having the power to push the signal). I got tired of arguing and got off the phone. I pulled a new cable directly from the router to my jack and plugged that into the tv. This one was longer than the last since it went through the attic. Surprise! the issue returned. I plugged the shorter cable back in and I could login again; However, this time, I tried watching a show and found that while I could login, the connection wouldn't work for viewing.
So I want back to work trying to diagnose; I grabbed a hub and plugged the tv into the hub and the hub was connected to the network. It worked better was but still very spotty during playback.
My feeling is that this is a bad Ethernet controller on the tv, but I have no idea how to prove it. The shorted the cable, the better it seems to work, but at this rate I would have to watch the tv in my Foyer ( which is where the router closet is ) I hate to take back the tv, but it might be my only option.
A few other notes, the tv can get an ip address. I can ping the tv from my computers. The tv says it can access the internet, but nothing works.
So my question is this, has anyone heard of anything like this? Is it feasible the ethernet card on the tv is bad? If so, what can I do to prove it?
thanks
Ashley
thanks
Ashley
