MOBO: P5B-E
Sound from back panel is fine. I just get none from front of case.
I checked the connections and it looks right.
Case: COOLER MASTER Centurion 5 CAC-T05-UB
http://www.newegg.com/product/product.asp?item=N82E16811119047
Front panel case wires:
There are two connectors and a bunch of individual small connectors that come from the front on the case. One says HHD, the other says AC97, then at the end of the wire is a bunch of individual connectors. I connected the HHD to the motherboard and set the BIOS to HHD.
Not sure what to try now. Any ideas?
