Im not sure why my orginal thread got deleted, but it probably had something to do with the lines. That I only wanted a good answer and good people. Im having a problem here it is
No its not a mental problem. but here goes again
ive reinstalled Windows 7 , I have my old program files directory with my games. They are cracked, because im too lazy to use the dvd's and change them all the time. So I know they dont have to be installed the long way because theyve worked when Ive reinstalled before.
But I cant remember what things I had to put on to make the majority of them work. : NFS hot pursuit, GTA4, Cyrsis, Deadspace, all them.
Ive put on Direct X 11, Runtimes from Direct 9 and most distros.
Though Ive tried to put on Visual C++ runtimes, i tried removing them after I put everyone I could find on, and now they are a bit broken up where I cant uninstall them from the program add remove menu off control panel.
So one quick question. If I am running Windows 64, do I need to install the x86 packs. Because I have been, and did so last and previous working install of windows both packs. ? This is worth a lot to me even know that.
Since I just put on the OS, Im sure it cant be as silly as reinstalling it again.
I used IOBIT uninstaller, to rid the other visual basic runtimes, but they are left on the program add/remove still.
NVIDIA is installed newest drivers,
all chipset mobo/etc installed
audio right
Direct X 11 , with runtime distros from past
Visual C++ 2010 x64.
Mostly every game just hangs.
when loading up,
Should I kill windows with a bazooka?
audio right
when loading up,
