Greetings mighty gurus,
I bought a new PC and booted it up. Only the hardware was fully factory-prepared. After the first start I had to install Win 8.1, all the drivers, settings etc. The problem is I still can't connect my monitor through HDMI cable, I get the "no signal detected" error. However, VGA with DVI-I adapter, which is located on my GPU (this is important), works well.
HDMI port on the monitor and all the cables work fine, I checked that on my notebook, and it connected and displayed in a few seconds properly, so I guess it's not a HW problem.
The only and single HDMI port is located on my motherboard, while the monitor has two HDMI inputs. The graphic card (surprisingly?) has no HDMI ports, as I expected it to have. But the DVI-I port on GPU is working, when connected through a DVI-I adapter to VGA cable. Other ports on the motherboard are working too, like USB etc. When I tried the direct VGA connection, I found out the VGA on the motherboard does NOT work - no signal detected.
So I guess it has something to do with the BIOS configuration - I probably need to switch the default video output from GPU to motherboard. I read somewhere on the internet, that the GPU attached to motherboard is somehow taking control over the motherboard's video ports. So I entered the BIOS and "randomly" tried to switch a couple of settings, without luck. I hoped there will be some kind of clear "select video device input" option or whatever.. but that's where my knowledge ends.
Any tips how can I get the HDMI on motherboard to work? Or which BIOS option enables the motherboard HDMI port? Thank you very much!
Monitor:ASUS VX248
GPU: NVIDIA GeForce GTX 750 Ti
Motherboard: ASUS 8XM-A
Windows 8.1 fully updated
I have a motherboard driver CD, NVIDIA graphic card driver CD etc. I installed everything and I think the drivers have nothing to do with the problem.
Monitor:ASUS VX248
