I have installed windows 10 but now no usb port works, even keyboard is not working.
Just my touch screen is working .
Any solution? 😊
Any solution? 😊
I think you should use a USB Hubs to expand your laptop port. I use Larnt's 4-port USB Hubs for mouse, keyboard, USB Stick, and leave a port for spare.
I got it wrong, I thought the port was occupied.How would that help?
If his PC's ports aren't working then neither will a HUB.
@Legendrashed6 Install your motherboards chipset drivers from the manufacturers support section of your motheboard.
this is the usual cause, yes.So it is because the internal driver is not installed.
