'no input' when using extension cable
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.video (More info?)
[CC to mail is appreciated but not obliged]
Hello,
I have recently bought a VGA extension cable (5m, f->f) and a gender
changer (m-m). When I use them together to connect my monitor to my PC,
my monitor says "no input". But when I do the same with another PC and
another monitor, it works fine.
My monitor is a Medion MD1772LA, a few years old. My PC is a newly
bought Asus Pundit Barebone with SiS video chip.
What might be wrong?
yours,
Gerrit, who wishes to extend the distance from terminal to computer.
Ervaringen met het Syndroom van Asperger:
http://topjaklont.student.utwente.nl
Socialistische Partij:
http://www.sp.nl/
"Gerrit Holl" <Gerrit@nl.linux.org> wrote in message
news:slrnc6od93.3ml.Gerrit@topjaklont.student.utwente.nl...
> Hello,
PC,
> yours,
Could be that the resistance drop of the cable you bought is enough to
reduce the video signal such that your monitor cannot detect that
anything is attached. Try connecting the 'other monitor' to your PC with
this cable. Or try putting the graphics card from the 'other PC' into
your PC and see if it works then.
Mr N.
I'd bet that a 5+ meter video cable is too much of a capacitive load for the
onboard video chip to drive.
DaveW
> Hello,
> yours,
> http://www.sp.nl/
> PC,
Thanks for the information. I will try so as soon as I have the
opportunity (next monday) and report the result. My graphics card is an
onboard chipset, SiS 650. Suppose I find that either my monitor or my
graphics card is too weak - does that mean I need to replace it, or does
such a thing as a video amplifier (intesifier?) exist that would solve
the problem? I don't see it in the list of the shop where I bought the
cables, but it might of course be a specialist thing.
yours,
Gerrit.
http://www.sp.nl/
news:slrnc6qkus.c87.Gerrit@topjaklont.student.utwente.nl...
gender
> > PC,
and
to
with
into
an
Can you disable the on board video so that you can insert an add-on
card?
does
I have seen video amplifiers for sale; can't remember the price but I
would imagine they would be very expensive, being a specialist bit of
equipment.
If you can prove that the on-board SIS video is not putting out a very
strong signal, i.e. another graphics card works, I would go with that
one or buy a new graphics card.
As the SIS is onboard, it could be that there is quite enough power
being fed to it. I am clutching at straws here, but it could be your PSU
is a bit weak or it could just be that SIS chipset (never liked them
myself let alone onboard graphics)!
Hope it works out for you,
bye for now
Mr N.
mrnobby wrote in comp.sys.ibm.pc.hardware.video:
[snip]
> PSU is a bit weak or it could just be that SIS chipset (never liked
> them myself let alone onboard graphics)!
[snip]
Hi,
I was just looking at another thread in this group.
Message-ID: <Xns94BBCF686BA2Ajohnchojohnchous@199.45.49.11>
Subject: What the heck is Input level?
It seems that there are different standards about what voltage
should be used for video card to monitor connections. I am
guessing that the SiS chip is using the newer lower voltage,
and I know that some monitors are configurable for 0.7Vp-p
or 1.0Vp-p. Check your monitor.
Sig goes here...
Peter D.
