[SOLVED] no internet with ethernet cable but it's fine with wifi
Peter_131
98
Hello guys!
So I have just got an ethernet cable since my internet speed was way too slow with a WiFi connection using a dongle.
I have connected the PC to the router (it's a modem and router 2 in 1) with an ethernet cable but there is no internet now, I can't see any networks only the Wifi works. I have no idea what could be the problem.
did you activate lan card on the board and try to reset router to see if it wil detect the lan cable plug in you might have to check your router settings to see if lan is not disable .
