So i had no issues after upgrading my system a few weeks ago. Ran great!
Previous system specs:
GTX 1080ti
Gigabyte Auros x570 elite
corsair 3000mhz ( cancelled the overclock for now, so it's 2133mhz ) 8gbx2
750W Thermaltake RGB Tough power
CPU Ryzen 3600
Water cooled AIO
Upgraded components:
RTX 3080 MSI ventus
Same motherboard
Gskill Trident Z rgb 3600mhz 8gb x2
Same Power supply ( 750W should be sweet spot )
Ryzen 5800x ( got it for a great deal at local online retailer )
Water cooler has been upped to a corsair H115i RGB Platinum
NVME is a samsung 960 evo 250gb as my main , secondary is a 500gb SSD
Everything was fine, no issues, great gaming times, fps at 1440p was a blast, then one day, BSOD.
I started checking why and what, updated all my driver to make sure, no difference.
Ran memtest, no issues, changed them over into the other slots as well.
Component reseating was followed shortly after that.
CMD commands were run to check for faults with no problems picked up. The BSOD's started to become more frequent and everyone of them had a different error displayed.
I could play a game like warzone of battlefield or dota with no problems. Once i idle in the menu or on the desktop browsing chrome, BSOD! Chrome made it worse somehow, firefox seems to be less aggressive at this stage.
I've done so much searching and troubleshooting that i just can't find the issue. Ram is fine, temps are fine, ram was swapped with another kit, ssd was swapped in to check the nvme for issues.
I've placed my dumps in this we transfer link, pleas please someone assist!! I can't work or play anymore.
https://wetransfer.com/downloads/bcb557004fc47066754420262b00275b20210201181945/f9fe8a
I hope you all can see something i dont.
FYI, pc has been restarted 6 times now, everytime a different model like 1904, 1909, 20H etc etc. All do the same! I've checked my network drivers, as i saw that peaked an interest in my event viewer. No change after upgrading.
Your help would be greatly appreciated!
GTX 1080ti
CPU Ryzen 3600
Water cooled AIO
RTX 3080 MSI ventus
Same motherboard
