No monitor signal but fans, working
andrei1098
7
I've recently finished building my first pc and my monitor says no signal but all parts are functioning. btw i used hdmi cable from the monitor and connected it to the motherboard's hdmi port and monitor says no signal. i doesn't have the gpu, i just want to try if its working so i tried turning it on and still no display on the monitor. these are my system specs:
Corsair CMK16GX4M2B3000C15R Vengeance LPX Kit of Memory RAM 16 GB, 2x8 GB, DDR4, 3000 MHz, CL15, Red
Intel Core i5-7600K 3.8GHz 6MB
NZXT S340 Elite Mid-Tower
Seagate Hard-disk ST1000DM010 Barracuda Sata III 7200rpm 64MB
Corsair CX650M CP-9020103-EU Power Supply ATX/EPS, Serie CXM da 650 W, Semi Modular, Certificazione 80 Plus, black
Corsair Hydro H100i CW-9060025-WW liquid cooler
MSI Z170A GAMING M5 Motherboard for Gaming
Samsung S24D330 Monitor 24'' Full HD, 1920 x 1080, 1 ms, 60 Hz, D-sub, HDMI, Black
These are all new and still don't know why my monitor doesn't have display. should i wait for the gpu? please help me i've spent a lot of time, effort and money for my first pc build. really hope you can help me. thanks a lot
btw i also have a SSD samsung evo 850.
[two posts merged by Moderator]
well you should 1st check the PC with only One Ram Stick if it still doesnt boot then use VGA or DVI cable and check
and your Board Gives what code? your motherboard has Q-Led Code
i will try the ram stick thing. my mobo doesn't have system speaker so i don't receive any beep.. the q-led code is 62 and according to manual nothing is debugging if it's 62.
