no monitor signal
Just wanted to make sure you use the right I/O ports for a monitor. But it could be a faulty cable, and I would try a different cable first, if you have one lying around. Then I would try a different monitor. If it still doesn't work, then I would blame the graphics card, and see if the drivers are correctly installed. Check here for NVIDIA. IF STILL no luck, then I would return the entire computer.
Let us know what you find out first though.
