No Networks Found, Theme Changed, and Running slow with low cpu and ram usage, help please
BoomasuresRex
18
My computer currently will not show any networks, has the basic themed on and wont be changed and is running very slow while only using about 5% CPU usage, and about 15% RAM usage.
My specs are
GTX 660 ftw
i7 proccessor
corsair 600 power supply
12 gigs RAM
running on windows 7
I have called ASUS support for help and they got me to uinstall and reinstall current drivers off thier website by downloading them to my laptop (an ASUS chromebook) copying them to a flash drive, then installing them to my other computer. It did absoultley nothing, niether did anything else they told me to do which, to be honest, i didnt understand how it would change anything in the first place. The final solution he came up with was to fully factory restore it, however with the 2 terabytes worth of games and slow internet speeds to try and redownload them it would take years. But knowing them they dont know everything so please anythooughts? Thank you
Sorry should mave mentioned this but i tried it and when i go to the program to do it, it says "This program is not running correctly on this computer" Or at least the same basic thing worded diffrently.
Hey there,
I got to - till now - no end, with similar parts as yours: GTX 660 OC 2GB
i7 proccessor
corsair 650 power supply
16 gigs RAM
running on windows 7 and yesterday my CPU said I'm gone. And she did. Working on, trying to find out whats wrong. My CPU went off and I can turn it on for 10 secs, each half hour or so.
I'm trying to say, that there might be something with those components, when they hook up together.
Did you find any answers?
Cheers!
