No overheating, High Cpu,High Fan Speed
kahfa92
A little time after start-up as it is waiting idle, fan speed is increasing abnormally,There is no sign of overheating but then it shuts down itself.I've cleaned the fan.All of unnecessary programs aren't being started.System applications only but it constantly shut down itself.
Thank in advance
I'm going to suggest checking your temps with a program such as SpeedFan http://www.almico.com/speedfan.php or CoreTemp http://www.alcpu.com/CoreTemp/ or HardwareMonitor http://www.cpuid.com/softwares/hwmonitor.html
I suspect heat is the issue but see what one of the above programs tell you for temps (I personally prefer CoreTemp)
When the fan was cleaned, was the laptop disassembled? Was the heat sink assembly removed?
