No Picture after leak
Lorenz_4
4
Hallo,
So I watercooled my pc and because i was in an hury one tube leaked...
It was spilling on the gpu heatsink and the mainboard.
I drained my system and let it dry for about 3hours.
Then I let the hairdryer blow on it for about 30min. It looked completly dry and so i turned it on.
Every thing was normal for about 2hours but then, i dont know if it was because of the water or a driver update but speedfan told me that my gpu was -999° hot and somehow in afterburner i wasnt able to overclock my cpu. At this time i thougt it was the driver.
And so after 4 hours of 4k gaming
Windows always told me that a usb isnt working right. I tried to plug everything out but i still got this message.
So i restarted the pc and had to make a Windows update.
After i was 100% completed my computer turned off but never turned on again.
So i turned the Psu off and on and started the computer. The fans where spinning and my mainboard lighed up but ther was no Image. I tried this a few times but there sgill was no image!
Please Help
3 hours to dry is very little time. Also the hairdryer might have damaged more the components if you had it too close or if the air was too hot.
You shouldn't have booted the PC for at least 24 hours.
I am not sure what you can do right now but try to boot with your Integrated gpu. If you see signal then your GPU might be the issue or the pcie slot of the mabo damaged. Try also seating the GPU in another pcie slot.
Ok
New mainboard has arrived
-N1.gpu is dead
-mainboard is dead
Is there smth. I can do to fix it?
Or are they lost ( id really want to somehow revive the gpu
1 question:
I had another r9 290 in there which got a little bit of water but is now functioning exept for 1 thing:
I cant overclock it over (the i think standert) 977mhz
Do u think this is a driver problem or waer demage
