Hi,
I just bought a new build, everything is new, except the PSU:
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($409.89 @ OutletPC)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($156.98 @ Newegg)
Memory: [CMK32GX4M2B3200C16] Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-3200 Memory ($444.99 @ Amazon)
Power Supply: be quiet! - STRAIGHT POWER 10 CM 800W 80+ Gold Certified Semi-Modular ATX Power Supply
After building it, it was not posting. So I began to troubleshoot.
I followed the troubleshooting sticky and I'm currently breadboarding it.
Ripped everthing out, except 2x power ATX cable and cooling fan, to start from scratch on breadboard.
My diagnosis so far:
- With only CPU in: 3 long beeps. (> as expected)
- Next step, I put one RAM stick into B2 (regarding to asrock forum ): doesn't beep anymore.
I either expected a one short, 3 long beep for "No VGA" or a short beep for successfully posting (because i7-8700k has a video card on board), but not nothing.
One time it did beep a series, but I can't remember which kind of beeping. The sticky says it may now be an issue with the PSU, did I understand this right?
EDIT/UPDATE:
So I just tested it with a different PSU [BeQuiet Straight Power E9-450W] and it still beeps 3x long without the RAM and with the RAM in it doesn't beep.
That means it is the RAM and not the PSU, doesn't it?
Asus Beep Guide is very unclear. What does "normal" mean? Does this board not make a single short beep after posting?
UPDATE2
Meanwhile I tested every slot with [strike]one [/strike]both sticks. How possible is it, that 2 sticks are faulty? So it's not the memory?
Is there anything more I can do to confirm this? Is this maybe the wrong RAM?" Silence indicates that the RAM is shorting out the PSU (very rare). "
EDIT/UPDATE:
UPDATE2
