No post beep, replaced parts
Shortyrose
7
About a week ago my computer started shutting down a lot, figured out the Cpu fan stopped working, CPU got hot. Husband cleaned everything out, put back together - no post beep.
Had someone look at it, tried another PSU - still no post beep
Ordered a new Mobo - no post beep
Ordered a new CPU - no post beep.
fans works , no post beep and nothing to see on the monitor
NO beeps when taking out the RAM
Looked at the sticky solutions and triplechecked everything
PSU: 500w
Mobo - M68Mt-S2P
CPU: AMD FX - 6300 black edition
this is what it looks like
theres no led on the mobo
I dont currently, i might be able to get my hands on one this evening, I'll update the progress. Thank you
Yes the switch is on.. lol we had a friend come over and tested with his powersupply ( its a higher tier on the list than mine ) and still the same issue
maybe i LOOKED AT THE WRONG PDF BUT THE SIDE THAT THE WIRING FOR THE POWER SWItcH SEEMS TO BE ON THE WRONG SIDE?
sorry for the caps. ................. but the one I get to doesn't even look the same as the picture you posted. gigabytes site turned to a turd.
are you sure the BIOS on the board supported the 6core processor?
the wired switch is correct , if it wasnt the computer wouldnt even turn on ( as said the fans etc do turn on) and we checked compatability for cpu and mobo
we replaced it so its completely new and even if this was the case there is no way for me to get into the bios
