So I had this pc for 2 years, I wanted to buy a new case cause I got bored of the older one since it was just a black box. So I ordered a new one.
Since last week my pc has been acting weird, it wouldn’t post unless I turned off and on the psu, meaning I would hit the power button everything would run but no post, but when it flicked the psu switch on and off it would work.
my new case arrived today and I normally removed everything from the old case and moved it in the new one, i checked every cable, tried with and without gpu, check every ram slot but still, when I press the psu switch the pc starts automatically, doesn’t show anything on screen, fans work, hard drives work but for some reason the power button won’t work, meaning I can’t shut it off from there so I switch the psu off
Like I said I have tried removing and checking all of the components, except the CPU(since removing it won’t prove me anything)
I really need help, also to mention I don’t have a beep speaker in my mobo, and that there is a possibility my CMOS battery is dead, since my pc clock didn’t keep track and I heard that’s a CMOS problem
I didn’t change any components I kept everything the same just moved it to another case.
Everything is 2~ years old I never swapped any component.
Any help would be greatly appreciated.
Specs:
Motherboard:Gigabyte B450M DS3H
Ram:G skill aegis 2x8gb 3000mhz
Cpu:R3 2200g
Gpu:Gigabyte gtx 1060 3gb
Psu:Coolermaster master watt lite 400W
Os:windows 10
Case:Kolink void
Monitor:Samsung sync master s22b350
Specs:
Cpu:R3 2200g
Os:windows 10
Case:Kolink void
