Hi everyone, I'm building my 4th pc. (Christmas gift for my son). I've built 3 previously with no issues and this one is driving me nuts. I've read through your checklist and every thing seems to be in order. So here is my situation. If I have my videocard installed and plugged in, I get no post when plugged into the hdmi video ouput from either the video card or from the mother board. If I disconnect the video card, I can post with the HDMI cable plugged into the mother board. with the GPU uninstalled, I have been able to install windows, and update drivers but as soon as I connect my video card, I have no video signal.
According to pc parts picker, there may have been an issue with my CPU and motherboard, I updated the BIOS on the motherboard as well but no change. My next step I think is going to try to use a display port cable in the video card and see if that changes anything, but after that I'm completely lost.
Thank you so much for reading this and I appreciate any help you can give.
My build is as follows...
ASRock B450M PRO4 AM4 AMD Promontory B450 SATA 6Gb/s Micro ATX AMD Motherboard
OLOy WarHawk RGB DDR4 3600 (PC4 28800) 16GB (2 x 8GB) 288-Pin Intel/AMD Ready Desktop Memory Model MD4U083618BEDA
MSI Radeon RX 570 DirectX 12 RX 570 ARMOR 8G OC 8GB 256-Bit GDDR5
Thermaltake Smart Series 500W SLI/CrossFire Ready Continuous Power ATX 12V V2.3 / EPS 12V 80 PLUS Certified Active PFC ...
Crucial MX500 250GB 3D NAND SATA 2.5 Inch Internal SSD
