No Power Connectors for Graphics Card
ProKillerIV
Commendable
May 23, 2016
I'll be buying a GTX 950 for my PC, but my PSU doesn't have the appropriate power connectors, I'll be buying this Graphics Card.My power supply is a dr-8460btx 450w , can I use a (dual) 4 pin to 6 pin connector? Are there any drawbacks on using one of these? If it's fine to use one, could you link me one from amazon? (amazon.co.uk preferably)
Also since it's a pre-build PC bought from a store, it did not came with any screws for expansion cards, which screw type ,length (etc) do I need to buy?
to be honest i recommend changing your entire PSU because its not that good and not reliable i won't risk it with my system , and about the pins i dont have any info abt it... sorry
