Hello. At some point during the day, our PC turned off, but the keyboard lights and the light on the USB stick that happened to be in the slot were on. (It's a DIY build w/components listed below. It's been working since Oct 2016 when we built it.) It would not turn back on using the power button on the front of the case. We turned the toggle on the PSU to off for about a minute, then toggled it to on, and turned the PC back on. It worked for a few hours and then turned off again. (No on-screen messages appeared while in use.) We repeated the PSU toggling, but this time the PC would not power up.
I notice that when I toggle the PSU from off to on and press the power switch on the case, the CPU fan and case fan move about a half of a rotation, or "twitch", and the Audio Boost light on the MSI 970 Gaming mobo flashes, but that's it. Nothing else visible or audible happens. (I have to wait for about 15 seconds with the PSU toggled off for the fan twitching and mobo light to flash.)
[Upon inspection, I do see an oily substance that appears to be coming from under a heatsink on the mobo...not sure if that is relevant.]
Any insight into what might be causing this and/or trouble shooting steps I can take to help diagnose the problem will be greatly appreciated. Thanks!
PC components:
Motherboard: MSI 970 Gaming
CPU: AMD FX 8320
PSU: Inland ATX ILG-600R2 600W PSU
Graphics Card: XFX Radeon R9 380 2GB
RAM: EVGA 16GB DDR3-1600 (PC3-12800) CL 9 (two 8 GB modules)
HDD: Seagate 1TB SATA
Case: Corsair Carbide Series 100R Mid-Tower
PC components:
CPU: AMD FX 8320
