Question No Power - Faulty PSU or Motherboard?
Aug 7, 2022
5
I have been facing issues powering up my system for the past 4 days, LED lights on motherboard in on though. The puzzling issue is at the start of each day, I am unable to power up the PC. Each time I had to try out different method, opening up the case, disconnecting Power Sw from the panel and etc. And after messing with it for awhile I was finally able to power up the PC. Subsequent power up throughout the day will work and I can even get to game the entire day without any single issue.
For instance, just today, I had the same issue and had to try out different methods. I removed the power switch pin and tried to short the pc to power up but to no avail. However, after I placed back the power SW pin back on motherboard, the power button on case works miraculously and I was able to switch it on again. This makes me wonder what's exactly faulty here and I need your advise.
Thank you in advance.
Specs:
Motherboard: ASUS TUF B45-PLUS GAMING
CPU: AMD Ryzen 5 3600
GPU: ZOTAC Geforce GTX 1660 SUPER
RAM: CORSAIR VENGANCE RGB 32GB 3200MHZ
PSU: THERMALTAKE SMART RGB 600W
Storage: Transcend MTE110S 512GB SSD
Specs:
Replace the psu....test.
Lutfij
That isn't something that shouldn't be anywhere near a system. Perhaps try and source a donor PSU(borrowed from a friend or neighbor) with at least 550W of power for the entire system's disposal to rule out your unit being the issue.
If you have to reseat components, it's quite likely a grounding issue...
Reactions: white.a.drew
Aug 7, 2022
5
My apologies, i don't really get this sentence. Can you elaborate further.
Judging from things now, am i right to say that it doesn't seem like a mobo is failing?
Aug 8, 2022
I'm having the same problem have to reset every components for PC to turn on,
I replaced the psu same problem when I do get the PC to start it works fine no crashes
Switch it off the next day same problem
Reactions: bunbun33
Aug 7, 2022
5
I just replaced my PSU after 3 weeks of not switching off my pc. And the same problem occured, not able to turn on. Can i say its mb issue now?
Thermaltake's SMART range of PSU's aren't good quality units. it's hard to say if it's a motherboard issue.
Aug 28, 2022
8
I had the same issue a couple of years ago and it was an old contact in the wall socket overheating with too much load and would trip my pc. I t took me ages to diagnose it as i could not beleive this would be the issue!
Relocate to another wall outlet and see if the issue persists.
