No power, only fans and dvd drive light up
gageboy43
4
i have a AMD athlon x2 5000, dual core, 500gig hd, 2gig ram, radeon 4870hd graphics card, 650w power supply. Computerwont come on. no led, hard drive not spinning. Only the fans and the dvd drive working. help??
Try taking out your mobo and run it outside the case, a stand off my short the mobo.
Otherwise make sure the RAM is seated in the correct slots, if that doesnt work then try swapping the RAM, like stick A goes into socket B and stick B in socket A, if you get what im saying...
