No Power - Please Help
ranger133x
129
I'm not sure if this is my mobo, case, or psu (however, I presume it is likely the mobo).
Sometimes (quite often) when my computer gets turned off it won't turn back on. I can press the power button over and over and it won't work. At random, one of the attempts will work and the pc will boot up.
I have developed a method where I toggle the switch on my PSU, then I press the power button a bunch, then flip the switch, press power button, flip switch, press power button (over and over again). Eventually the computer turns on.
I feel like it is an issue with my mobo. I have checked the connections in the chassis, and they all seem fine.
I hate turning my computer off because I'm afraid it won't turn back on (potentially never again). But things can't go on like this.
Please help!
Thanks!
It can be a faulty PSU as well. If possible, try testing with another PSU.
It can also be as simple as a faulty switch. If you know where the start switch header on the mobo is, try manually jumping them with a piece of metal to see if your system starts.
Latest posts
