No power since power outage, Please help!!!
goosemasterkl
9
Since I had a power outage my Dell Inspiron 570 desktop has yet to power back up since. I've tried 2 motherboards, a processor, checked all the memory cards but still no luck. Please respond!!!!!!! I need help. Thanks
You were using a power surge, correct? And you said you tried two motherboards, a processor and RAM...but did you check the power supply? Have you disconected everything, waited 30 seconds, and reconnected it again?
Does anything spin? Does the monitor power on? Speaking of that, does any thing from THAT outlet work?
I jumpered out the green and black wire on the power supply and all the voltages were correct coming out the 24 pin. When it's jumpered the dvd rom and hard drive will power up. but only when I jumper the power supply.
Herc08; I went ahead and ordered a power supply yesterday hoping it would be my problem. Thanks for your input and I'll post up after I put the p/s in to see if that fixes it. Thanks again.
Herc08; I just installed a different power supply and still NOTHING. I've tried 2 MB, a processor, removed and installed my memory in different slots. Tried it with 1 stick, then 2 and then all 3. Still NOTHING. Someone please advise. Thanks
