Hi guys.
I have had the same build for th last 4 years no issues really.
Sharkoon case
Intel i7 4770k haswell processor
Gigabyte ga-z87-hd3 motherboard
Asus gtx 950 graphics card
Corsair vengence 8gb ram
Ocz stealth xstream 600w power supply.
Intel stock fan
I always wanted to upgrade the stock fan and add some more ram. I decided to get these i went for hyper x 4gb ram stick and a hyper 212 evo cooling fan for my gpu.
Ram went in just fine funny though i had to put my corsair and hyper x in certain slots to get the computer to boot as it would stop and restart, after a few attempts it worked fine.
Few days later i put the fan in, bit fiddly to install as i had to take the whole computer apart to mount it but it went in okay and computer powered on and i even had a game running for a few minutes, that night i turned off the PC as normal and switched off the plug socket which i dont normally do, anyway next day i came in turned everything on and nothing. No power what so ever, i can sometimes hear a like static sound going into the psu but no boot or power.
I tried reseating everything, iv taken apart the whole thing and put it back together. Nothing.
Iv tried a second hand but working power supply from.a friend, still nothing. Iv taken my own and the 2nd hand power supply out and did the trick to plug wire into the 24 pin and they both run ok.
I have tried taking everything out of the case including mothetboard and connecting up still nothing. I have also tried with various components and no components still no power at all. I have also tried the old stock fan too from intel.
I have an old dell inspiron 530 pre built i put my power supply into it and it doesnt run the fan spins for a second and cuts out, the second power supply runs it fine? But yet my own will run with wire in it. Im wondering is my board and my power supply shorted or blown?
Im really confused and really stuck on as to what to do, i dont want to buy a new board as i dont have much money.
Could any one help?
Thanks for reading.
Edit - id understand static or if i shorted something during installation but it was working fine i had a game running i just cant get it to power on.
Makes it worse its my birthday on monday and i booked off a long weekend off work to play some games.
Sharkoon case
Intel stock fan
Could any one help?
Thanks for reading.
