I've done my best to search online before posting these questions. I've looked up people with similiar problems but I'm not getting the same results with the troubleshooting.
I built my house new and requested to have it wired for the internet. I have 6 RJ45 jacks in my home which all lead into a main floor closet. These are CAT5 cables and have RJ45 connectors on all of them and the electrician who did the wiring labeled each CAT5 cable to the correct room.
Also in this grouping of loose cords is another cord labeled HR.
My mindset is that this should be as simple as plugging these CAT5 cables straight into a router and having them work. This is not the case...
I have Time Warner Cable and I've tried to plug some of the lines into the modem / router they supply. I've went from Modem > NightHawk Router > All cables plugged in
I've done Modem > Gigabit Switch > All cables plugged in
Modem > Router > Gigabit Switch > All cables plugged in
When I ordered this networking with the home it was on my upgrade list as "Ethernet Ports for DSL" - So is it possible that cable internet simply won't work? On Friday the 16th I will have ATT fiber installed but I dunno if that will do anything anyways.
I've tried to call local companies to come to the home and fix this but unfortunately everyone is booked for 3+ weeks.
Just to wrap my head around this....
Ideally, this shouldn't be that difficult right? If my cable modem and router are properly installed I should simply be able to plug the master bedroom CAT5 line directly into the back of the router and it should work correct?
I ordered a port checker from Amazon for $10.00 and I will start there. Is it possible that the home being wired for DSL they used some kind of inferior cabling? It says CAT5 on the sleeve I assume CAT5 is CAT5.
Thank you in advance for the direction
