My Asus fx504 laptop is about 3 months old. When I woke it up from sleep mode the other day, whenever I tried to open a program I was met with;
"The application has failed to start because its side by side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail."
This occurs with almost every single program on my computer with the exception of Chrome for some reason.
Some solutions I have tried already were:
Finally I tried to reset my entire PC because I was sick of the error but in the reset process, it failed and sent me back to windows. I tried this multiple times, as have I with all the other things mentioned.
Please someone send me in the right direction here, I'm running out of ideas.
■ running /sfc scannow in cmd prompt which failed during the process.
■ I also tried check which specific c++ redistributable was missing under the advice of the internet by going into the windows error thing and check exactly the error for any given program that i was trying to open but it did not give the info needed.
■ I tried to install new c++ redistributables but when i download them and try and install them the same side by side configuration error appears when I try and open them.
■ I tried to uninstall old c++ redistributables but they all said "this program doesnt appear to exist, would you like to remove the program from the list" which if I agreed to did nothing and it stayed on the programs list.
