G
Guest
Guest
My system is 1,5 years old by now and has been working flawlessly until today.
When i tried to turn it on nothing happened, nothing at all. I checked that the power was on and tested other electrical appliances that worked fine in the wall plug. I switched around the reset and power button and back again while checking that all the wires inside were seated correctly. No dice. But when i took out the power cable from the PSU and plugged it back in the fans spun for a brief moment, without me pressing any buttons. This didn't repeat itself afterwards though.
Anyone else experienced this problem?
Specs:
MB: MSI Z87-G45 Gaming, Socket-1150
CPU: Intel Core i5 4670K @ 4.0 GHz
GPU: MSI GeForce GTX 760 Gaming 2GB
PSU: Corsair CX600M 600W
RAM: Crucial DDR3 BallistiX Elite 1866Mhz 8GB
HDD: WD Desktop Blue 1TB x2
Case: Fractal Design Arc Midi R2 Sort
Specs:
