B beachgator Dec 26, 2018 3 0 10 Dec 26, 2018 #1 My son's motherboard only has one PCIe slot which he has placed his graphics card. We need to place a wireless card in the system. Any suggestions?
Solution faalin Dec 26, 2018 Unless his card is a 3 slot card this would work in his lower PCI-e X1 slot https://www.newegg.com/Product/Product.aspx?Item=N82E16833320340&Description=wifi%20card&cm_re=wifi_card-_-33-320-340-_-Product
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Dec 26, 2018 #2 An USB based adapter: https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=usb+wi+fi+adapter&rh=i%3Aaps%2Ck%3Ausb+wi+fi+adapter Try selecting one based on budget and reviews (something like https://www.amazon.com/gp/product/B07GVDTXRZ/ref=ox_sc_act_title_1?smid=A2KR2FPOLD5FE0&psc=1 ) Upvote 0 Downvote
B beachgator Dec 26, 2018 3 0 10 Dec 26, 2018 #3 alexoiu : An USB based adapter: https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=usb+wi+fi+adapter&rh=i%3Aaps%2Ck%3Ausb+wi+fi+adapter Try selecting one based on budget and reviews (something like https://www.amazon.com/gp/product/B07GVDTXRZ/ref=ox_sc_act_title_1?smid=A2KR2FPOLD5FE0&psc=1 ) Thanks for the suggestion. I knew that a USB option was available, but I wanted to see if something else was out there. Upvote 0 Downvote
faalin Illustrious Feb 22, 2012 6,353 509 41,740 Dec 26, 2018 #4 What motherboard do you have? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Dec 26, 2018 #5 "Thanks for the suggestion. I knew that a USB option was available, but I wanted to see if something else was out there. " No problem. Apart from integrated, PCI/PCIe and USB? Not sure what else... Upvote 0 Downvote
B beachgator Dec 26, 2018 3 0 10 Dec 26, 2018 #6 faalin : What motherboard do you have? MSI B450M GAMING PLUS AM4 AMD B450 SATA 6Gb/s USB 3.1 HDMI Micro ATX AMD Motherboard. The only slot was taken up by his video card. Upvote 0 Downvote
faalin Illustrious Feb 22, 2012 6,353 509 41,740 Dec 26, 2018 Solution #7 Unless his card is a 3 slot card this would work in his lower PCI-e X1 slot https://www.newegg.com/Product/Product.aspx?Item=N82E16833320340&Description=wifi%20card&cm_re=wifi_card-_-33-320-340-_-Product Upvote 0 Downvote Solution
