So the other day I decided to clean my prebuilt reapply thermal paste and dust it. First time ever doing this everything went well with my gpu but everything turned for the worse once my cpu came up. I got all 3 screws off my cpu fan but the fourth one was stuck like someone tightened it with all their might. I went at it from all angles for hours on and was turning the back plate to my cpu to try and unhook it or twist it from that way and I accidentally chipped away some parts where the cpu sits that the back plate is supposed to protect.
I gave up on the screw put everything back together turned it on and was getting no signal from my monitor. I checked everything made sure everything was plugged in and then noticed on the back of my motherboard damaged pins where the motherboard sits and I’m not sure if that could be the issue because even when I finally got the screw off and checked my cpu all my pins were intact. I ordered a new motherboard hopefully that was the issue or I just wasted money.
