M Michal1012 Honorable Mar 11, 2015 16 1 10,515 Apr 25, 2018 #1 I opened my pc and took out the ram to check it. When I putted it back in and turned on the pc, the monitor showed no display. I was very careful with the ram so I couldn't damage it
Solution J J jay32267 Apr 25, 2018 Shut the PC off....unplug the power cord, touch the case, and do it again. Make sure the sticks are seated correctly. I have seen sticks that seem to be seated correctly but aren't. Also while the sticks are out, check the slots for debris, check the conductor terminals on the stick for anything out of wack.
J jay32267 Champion Mar 16, 2017 10,702 1,324 56,940 Apr 25, 2018 Solution #2 Shut the PC off....unplug the power cord, touch the case, and do it again. Make sure the sticks are seated correctly. I have seen sticks that seem to be seated correctly but aren't. Also while the sticks are out, check the slots for debris, check the conductor terminals on the stick for anything out of wack. Upvote 0 Downvote Solution
