Hey guys, this is my first post so I don't know if im in the right area, but I need some serious help.
I put together my first PC today and everything looks as if it's working properly. The fans are spinning, power is flowing to the motherboard, and the LEDs are on. The only problem is the connection between the PC and the monitor. Every time I hook up the monitor to the graphics card via DVI-D, I get a message on the screen that says "no signal DVI" or "DVI no signal". I'm going to post a list of the troubleshooting that i've already attempted and my system specs to help you guys narrow down the problem easier.
Here's what i've done:
1. Double checked that the GPU was seated properly
2. Double checked the PCI-E connections
3. Tried using both the DVI cable and the VGA cable
4. Moved GPU to a different slot
5. Switched to a different PCI-E cable
6. Removed graphics card and connected DVI to the motherboard
Nothing is working!!! 🙁
Specs:
CPU: i5-3570k
GPU: EVGA geforce GTX 670 FTW
Mobo: Msi z77a-GD55
Memory: Patriot G2 DDr3
HDD: Seagate Barracuda 1tb 7200 RPM 32-bit
One last thing, The graphics card fan was NOT spinning when I tested the computer.
Thanks in advance for any help!
Specs:
CPU: i5-3570k
Mobo: Msi z77a-GD55
