No signal monitor
Mar 16, 2018
13
Hello, the other day I had to unplug my HDMI cable from my monitor and PC to move some stuff around. Today, when I plug everything back in, I cant get signal on my monitor. I have tried everything, removing graphics card, removing RAM, holding down power for a minute, etc. Nothing works. I really could use some help. Thanks.
These diagnostic LEDs are grouped with the functional area of the motherboard. In this case, the SDRAM slots are indicated. Consult your motherboard manual for the specific LED and the color for the meaning of the LED diagnostic. Different manufacturers use different colors. Yellow indicates an error condition (Asus for example). So you most likely have a problem with the SDRAM memory.
The individual LED diagnostic is usually labeled on the motherboard as well.
I have tried this, and I dont think it is a problem with the monitor. At first I thought it was so I borrowed a friends to try and it still doesnt work
Update, i just opened up the PC to take another look around and noticed a solid yellow light on the top right of my mobo. Its to the right of my RAM slots, but im not sure what that means. On top of that there is a green light all the way on the bottom right, which I presume is a good thing.
