Question No signal on 2nd monitor using a HDMI to DP cable
valeriu.2809
5
Hello, I just got a 2nd monitor from a friend that doesnt need it anymore and i really want to use it but the problem is I have Nvidia Geforce GTX 1060 6GB, which has 1xHDMI and 3xDisplayPorts. My main monitor is a Dell S2415H(HDMI port is used for this), and the monitor that I got is LG 34UM58-P (wide one) which has 2 HDMI connectors in the back it, so what I thought its an easy solution is to get a HDMI to Displayport cable and just plug it in, then enjoy my 2nd monitor, but the monitor doesnt detect any signal, the error is "No Signal, entering power saving mode shortly".
The cable that I bought is this:
Does anyone know if i need to do something else like activate the ports from Bios or something ? I tried pushing the cables in as much as I could as i know some people are saying they could not make proper contact ... Could the monitor being an old version not support the DisplayPort thing ?
Thanks in advance :)
valeriu.2809
5
valeriu.2809
5
Im not exactly use what you're asking me, they are DisplayPorts 4.0 (females), you can google the video card and see how they look (Nvidia Geforce GTX 1060 6GB ).
I'm going back to the store today and ask them to test the cable, maybe it doesnt work at all before I buy an adaptor, that's probably the best thing i can do right now.
Thanks
k1114
If the adapter is active then it's different but that won't matter as dp can run hdmi signal through it so passive cables/adapters can be used. Dp, hdmi, dvi are all digital and have no difference in quality. Gpus don't have input ports.
valeriu.2809
5
I bought another cable HDMI-DVI(m/m) and its working perfect. The guy at the store said that the cable works for the exact opposite situation, if I'd had the dp port in the monitor and the HDMI in the video card, it would've worked but not the other way around :/
