Question No Signal on monitor after Splash Screen
Aug 14, 2019
4
My Specs:
B450 Tomahawk
Rosewill Lepton 500 PSU
Ryzen 7 2700x
GTX 1060
256gb SSD
1tb HDD
I've had successfully booted this pc up the first time and installed windows as well as the drivers required for the GPU. But now when I boot up the pc, the splash screen loads but just when it's about to go into Windows the monitor goes black and reads no signal.
Try safe mode.
Before you enter safe mode, you need to enter the Windows Recovery Environment (winRE). To do this, you will repeatedly turn your device off, then on:
Hold down the power button for 10 seconds to turn off your device.
Press the power button again to turn on your device.
On the first sign that Windows has started (for example, some devices show the manufacturer’s logo when restarting) hold down the power button for 10 seconds to turn off your device.
When Windows restarts, hold down the power button for 10 seconds to turn off your device.
Allow your device to fully restart. You will enter winRE.
Now that you are in winRE, you will follow these steps to take you to safe mode:
On the Choose an option screen, select Troubleshoot > Advanced options > Startup Settings > Restart.
https://support.microsoft.com/en-us/help/12376/windows-10-start-your-pc-in-safe-mode
Aug 14, 2019
4
UPDATE; I did a hard reset by clearing the CMOS, and clearing the hard drive which Windows 10 is installed on. Now none of the EX Debug Leds is lit but still no post on the monitor
