No signal on monitor and CPU/DRAM/VGA/LEDs are flashing when start up on my Gigabyte H370 HD3 MB.. Please Help!
chammar
Commendable
Jul 24, 2018
12
Hello everyone,
A couple days ago, I built my first ever desktop, everything is done put into place (except for 3 fans), so I start it up. It seems as if it is booting fine, both cpu and gpu fans are running, small cosmetic lights on motherboard are on, my one rear fan (pre-installed) is on, my razer keyboard is lit up either when I connect it to the front USB 3 ports (case) or the back port (motherboard), although there is 1 problem. There is "no signal" going to my monitor. Initially I tried a monitor with a VGA port, no signal. Then tried a monitor with HDMI port, same, no signal.
I then noticed on start up (spamming the del button) the CPU led on the bottom right of my motherboard flashes, then the DRAM flashes, then the VGA stays lit up, solid red. So I'm curious as to what the problem is. My GPU is a Asus 1050 ti with NO PCIe port on it. I've tried a lot of things but no hope. Resorting to your peoples help!!! So thanks in advance :)
My Setup:
Motherboard: H370 HD3
CPU: Intel 8th gen 6 core i5 8400
GPU: Asus 1050 TI $4GB Cerberus OC
RAM: T-Force dark DDR4 3000 2x8gb
PSU: 500W Bronze EVGA
Ask if drives are relevant.
Hope someone can help, thanks.
To update, I took out the graphics card and the BIOS loaded. My graphics card does not require a PCIe port so I am thinking maybe the computer is expecting a connection (which is not there). Does anyone know what I can do to make my gpu work?
