No signal on monitor. but PC is working.
Necrospaci
5
My monitor will not register with my computer. This is my first PC build so I'm having a frustrating time dealing with this. I've tried many solutions but haven't had any success. My computer itself is running fine it lights up and the fans spin fine and dandy.
I've tried both onboard MOBO connect then connection through my GPU yet still "no signal". I'd appreciate if anyone could ho me since I've yet to see any video or guides to help me please and thank you.
These are my parts from https://pcpartpicker.com/list/DCMFNN
Intel - Core i5-6500 3.2GHz Quad-Core Processor
Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Asus - Z170 PRO GAMING ATX LGA1151 Motherboard
Kingston - HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory
SanDisk - SSD PLUS 240GB 2.5" Solid State Drive
Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
MSI - GeForce GTX 1060 6GB 6GB GAMING X Video Card
Phanteks - Enthoo Pro ATX Full Tower Case
EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Redragon - S101 Wired Gaming Keyboard w/Optical Mouse
Did you use any case fans?
Make sure your monitor is set to the proper input.
Make sure your GPU is seated properly. You will also want to make sure your using the 8 pin "PCI-E" Power connector coming from the PSU. Make sure the PCI-E power connector is plugged into the PCIE plug on the PSU.
That GPU requires a 400W PSU alone, but the PSSU Calculator might show you need less due to idle wattage being lower.
I have an air cooled pc with a 1st gen i7 980x and only a 6TX660. It has the CPU fan and 5 120mm case fans. If I am straining it, I can not open the side panel without the whole thing freezing. Please do not run it if you have not installed case fans and configured them for proper airflow.
