No Signal on my monitor.
sigurthor_is
Hello,
I'm trying to connect my GeForce GTX 570 to my monitor into D-Sub and the GPU doesnt have a VGA output.
So I bought a DVI to VGA Converter that i plugged into my monitor but the monitor says "No Signal Detectived".
What should I do ?
COLGeek
Cybernaut
Look at your manual to see which DVI port supports an analog connection (DVI-I). You may have connected to a digital only DVI port (DVI-D). For more info, look here:
http://en.wikipedia.org/wiki/Digital%E2%80%93visual_interface
