[SOLVED] No signal through HDMI and gva.
earnmoon
7
No signal to monitor through HDMI and gva. Tried 2 monitors which were working before(also tried putting the cable directly to motherboard) but my PC fell from a bed today, when I opened up the case the video card was popped out. (PC was working 100 percent before). So I tried putting the card back a couple of times but still says no signal. I am wondering if the card got broken or is it fault of the motherboard? The card is ryzen 3 1200 and Mobo is Asus prime 320m-k.
All the fans are working and there is no loose cables.
Well the CPU is a ryzen 1200, what about the graphics? Motherboard won't be able to produce a video output without an APU installed.
Obviously I would suspect physical damage, but you would have to provide pictures or something to say if it is the motherboard or the graphics card.
https://www89.zippyshare.com/v/z6hTUIjI/file.html
https://www89.zippyshare.com/v/zgzRCoS8/file.html
https://www89.zippyshare.com/v/7TWXscYM/file.html
https://www89.zippyshare.com/v/xGZGiMpx/file.html
https://www89.zippyshare.com/v/C5dY0FXX/file.html
There's a few pictures but I can't see any dents whatsoever. As u can see 2 cables are kinda unplugged but there's no space to plug them into.
The graphics card is AMD rx480 or something like that which is compatible with Asus Mobo.
I really can't think of anything more than buying a new card or Mobo...
