There seems to be a problem with my computer not detecting my DVI correctly. I had this problem before but reformatting my SDD and reinstalling windows did the trick, until I tried to hook up my second display again. I'd rather not reinstall windows once again.
What happened after the refomat/Windows install : Everything worked fine for days, then I decided I wanted to lay down and watch a TV show using my TV hooked up to HDMI. I used windows + p to extend display to get signal on my second monitor that uses HDMI, I immediately lost signal to my main monitor(DVI). Tried to restart the computer with the HDMI unplugged to regain signal but the BIOS splash screen is massive and I lose signal after the windows logo(Login screen). I can hear the windows startup and If I plug in the HDMI it works normally(For both monitors).
What happened before the format/Windows reinstall: Monitor went no signal when simply DOWNLOADING the newest drivers- not installing. Same thing with the BIOS splash screen being huge and hdmi working fine with the same monitor.
What I THINK is happening : Something in my computer is defaulting my main monitor to HDMI no matter if it is plugged in or not.
What I have tried : Using ddu in safe mode to delete graphic card drivers and reinstall drivers (Tried numerous drivers) , changing resolutions with nvidia control panel, using display detection in nvidia control panel, enabling VGA mode, turning monitor off.. countless others..
Evga Geforce Gtx 970
Asus Vg248qe Monitor
MSI z720 gaming plus motherboard
intel 240 gb SSD
16 GB G skill Ram
600W evga gold certified Power supply
Intel i5 6600k Processor
intel 240 gb SSD
16 GB G skill Ram
