No signal to monitor after installing GPU
imarteenez
19
Specs
Mobo: Gigabyte b75-d3v
CPU: intel i5 3470
RAM: Corsiar vengence 8GB
HDD: Seagate 500 gb sata 3
PSU: 430w
GPU: Gigabyte 7850 OC 2GB
For whatever reason when I install the GPU my computer gives no signal, however the fans on the mobo still run.
I've tried a different GPU and that worked, I have tried a 500w psu and that failed.
I have tried unplugging all other components not needed to boot to test if the psu is powerful enough, which still lead to no signal.
I have tried the gpu in a different computer with a 400w which worked.
I also tested in a computer of similar specs with a 500w psu and asus h61 mobo which didnt work either.
I hjave also tried installing all the drivers and also went into bios and set it to pci express which didnt work.
I have no idea what it could be, it appears the gpu works, there is enough power and it is compatible with the mobo yet it dosnt work.
Please help.
