Hi all,
So im here because im having an issue getting my pc to [strike]post[/strike] POST. This actually started awhile ago, but has now seemed to have gotten worse the last couple of days. What is been happening is on a cold boot i can't get the pc to POST at all, so i started by resetting the CMOS and generally after a reset the pc would POST. However, that no longer seems to be working, and i have spent numerous hours surfing these forums and others to try and get some advice on getting a signal back to my monitor. With no luck. Hence my post. Hoping someone here can help me..
What iv'e tried-
*Booting up pc with only CPU , PSU , RAM, GPU - no boot & no beeps
*Booting up pc with CPU, PSU, NO RAM, GPU - no boot & 3 beeps
*Booting up pc with CPU , PSU, RAM , ONBOARD GPU - no boot & no beeps
*Booting up pc with CPU, PSU , RAM , ONBOARD GPU , NO HDD - no boot & no beeps
*I have also tried one stick of ram in various slots..
*I have also tried a Different stick of ddr3 ram from another working PC
*I have also tried a Different PSU that ive had laying around (thermaltake toughpower 750w)
*I have also tried resetting the CMOS numerous times with no luck.
* I have also tried New Battery for motherboard
* I have also tried reseating the RAM and checked all connections everything seems fine
*I have also check CPU for bent pins and cant seem to see anything out of the ordinary
Just editing to make a note - that the motherboard powers up all fans are spinning etc. LED lights are all lit up Blue etc.
when i use to be able to get this rig to boot after clearing the CMOS it would run flawlessly until it was shutdown. And then i would have to go through the clearing CMOS process again on a cold boot.
I hope this is some help in helping me fix the issue, ill be sure to leave my PC specs below. Looking forward to any help i can get.
Thanks in advance :bonk:
SPECS
mobo - MSI z77a-g45
cpu - Intel 17 2600k sandybridge
ram - GSkill 8gb DDR3 1600
gpu - msi 560ti
ssd - kingston fury 240gb
psu - antec 900w HCG
What iv'e tried-
SPECS
mobo - MSI z77a-g45
gpu - msi 560ti
